Wanted to drain the radiator on my 6140r. Mechanic said to leave to drain alone and take hose off of right side. Looks like the drain is a plastic valve with a hex wrench needed to open. Don't want to break it in the cold and maybe not seal up if I use it. Any body with experience using the drain valve? Your thoughts? tia
