Nwmo | You can create tank mixes directly on the insight and then you have to ability to pick it from a list after it has been created. I would assume once you import them you would also have the ability to pick them from a pick list. I have never imported tank mixes myself, they are usually created in the field when I'm spraying.
It is a drawback however being limited on the space to name tank mixes.
Devin | |
