Posted 10/25/2018 08:53 (#7064168 - in reply to #7050755) Subject: RE: EZ Guide 500 RTK into FMX with EZ Pilot
NE Indiana
You can definitely output NMEA RTK strings from your RTK 500. You can either output through your COM or AUX port. COM port pinouts can be found in the 500 manual. I believe you will need pin 5 for data ground and pin 3 for Tx. We output from our 500s into our Ag leader planting/yield monitor using the COM port.
