Posted 9/28/2018 09:26 (#7013796 - in reply to #7010474) Subject: RE: JD 8245R with RTK guidance
Eastern Nebraska
It sounds to me like you may need an offset for the planter. Typically when you have guess rows that are the same, you can enter an offset in to correct this. Whats the terrain like? That may explain why it's on 30/30 on some passes but off 2 in each way on others.
