Posted 9/18/2018 16:39 (#6994930 - in reply to #6994769) Subject: RE: Slow Hopperwalker motor ?
just a tish NE of central ND
No help but it should be working if you truley have 12 volts. On my 4020, if you put both ground and positive on the right hand battery you only get 6 volts, but if you move the ground to the frame........ TWELVE VOLTS!!!! Ive screwed that up before......lol! (:
Hope this helps
