Search Forums | Classifieds (59) | Skins | Language
Card to go in a Pro700 Case
CASE3594
Posted 9/11/2018 20:27 (#6982999 - in reply to #6980998)
Subject: RE: Card to go in a Pro700 Case
Tuscola, IL
Needs to be 4GB or less.
Also, as stated above, how valuable is your data. The CNH card is expensive, but it's typically about half the cost of a service call when the display crashes. We've seen a lot of failures with random USB storage devices and you typically lose all of the information from the last key cycle to the point of failure. In many cases, this is a full day or good portion of a day. I've run across more failures at harvest than at planting, but have seen some failures in the spring. Unfortunately, the failures at spring usually mean the planter stops planting and the operator doesn't notice right away. Once it's discovered that the display is locked up, it's hard telling how far you've driven with the planter not planting.
It's worth a few more dollars for peace of mind to me.
