South Western Ontario, Canada | pjponch - 7/6/2018 01:29
Look to your upper right or left in the cab. There should be a rocker switch with two lines and maybe a steering wheel between the lines. I think that is the switch you need to push to make your steering work. It is a disable switch for auto steer when traveling down the road, so you accidentally don’t engage auto steer and the combine turns off the road.
On our 8120 the switch is on the arm rest. No other switch in the cab.
Have to hold that switch down for two or three seconds until the monitor beeps. |
