Search Forums | Classifieds (225) | Skins | Language
Sidekick Pro ISO voltage issue
Woltanac
Posted 6/12/2018 14:53 (#6808841)
Subject: Sidekick Pro ISO voltage issue
Windfall, IN
A guy I'm helping over the phone has a Sidekick Pro ISO connected to a 2630 with a GRC on an anhydrous ammonia toolbar. The injection pump runs, but his high current voltage is getting down to 8.7 volts on longer passes according to the Sidekick diagnostics readings. When he makes a turn the voltage slowly comes back up, but never to 12 volts. The 2630 shoots up a high current power error, but he can hit ignore and keep running. He ran this way all this year so far. The anhydrous ammonia application is fine and correct. It sounds like the Sidekick is applying properly. He doesn't have an alternator issue and has checked most of the cabling for 12 volts. Has anyone had this issue? Does it sound like something is wrong with the internal electronics of the Sidekick? I feel like something could be getting hot.
