NEIA | This is on a Massey, but it might have happened on others. This is planting so I have my markers as guides. When I start with my first A/B line it's ok. Turn around to go back and it will be anywhere from 4 to 8 inches off. I'll nudge it back over where it should be. Turn to go back and it will be right on line, but some times I will have to nudge it back to where it was. Rinse and repeat. I've just started to use the markers and hold on to the steering wheel. Played with it today in my yard. Did one line and turned around, was off 8 inches. Came back it was right where it should be. I tried it with the c3000 planter monitor, then the c1000 armrest monitor. Same results. Took the receiver off and put a different one on. Still the same thing. All my measurements and numbers entered are correct. Did all the calibrations a couple of times. Tried waas and Omnistar G2. Where do I look next? | |
