Boyden IA | This is a odd setup but...... Have a spare JD 2000 rate controller laying around and wanting to set it up on our field cultivator as a fence row + 5-10ft spray boom on the outer wing of our field cultivator.
We run the 4600 screen in a 9R. I have plenty of raven control valves, flow meters and boom valves as well as all the harnesses to make it run on our JDRC.
Is there a way to run a small electric pump instead of running hydraulic lines and a pump all the way to back of the cultivator?? TIA | |
