Claremont,MN | If you have the vacuum meters with a single hole for the seed to go into from the box then they will work with the eSets. Basically any meter after 1990 will work. If you want to go with vSet meters you will need the finger meter box or if VSet2 then the box from Precision. The vSet meters will use less vacuum volume at the same pressure. So if you are wondering if you have enough vacuum that might be a reason to go vSet. | |
