| Thanks tedbear.
I believe by copying the flowmeter calibration number from the Insight I likely bypassed any issues associated with having to divide by 10. It is a Raven flowmeter. Below you should see an image of the Insight screen associated with that (assuming it loads).
I will be a little surprised if we have a flowmeter issue. We used it last probably a week or so ago and we’re running 28-0-0-5s at that time and we have not had temps low enough for it to salt out. I was trying to get the last of it off before things got cold enough Sunday night for that to happen.
In regards to no speed, I found an area in the Integra manual that said check for speed in the upper right corner of the Run screen which I do have. In another place in th Integra manual it said the AIM diagnostics would show the speed of the backup signal which I am not using so I assume that is OK for that to read 0.
I will go ahead and update the Integra and modules this morning and try to get the sprayer started. If I can get it running and it still doesn’t work I’ll examine the wiring to the flow meter. Finally, if all of that fails, I will create a new configuration.
Thanks again!
(DA3CAA80-9EE9-4459-BD7C-3FD46399E84E.jpeg)
Attachments ---------------- DA3CAA80-9EE9-4459-BD7C-3FD46399E84E.jpeg (125KB - 90 downloads)
