roaming | catmendoo - 12/6/2017 21:05
Is there a difference between having a RangePoint RTX subscription or having the Glonass unlock? I am looking for highest quality signal for tiling.
RangePoint RTX includes GLONASS for the duration of the subscription. When your RP subscription expires, you no longer have GLONASS.
GLONASS by itself doesn't do anything for accuracy; the advantage of GLONASS is better satellite availability, which translates into fewer times when you're stopped because you don't have enough satellites.
RangePoint RTX is a correction signal, meaning that it increases the accuracy of your system over operating on uncorrected GPS (or even uncorrected GPS + GLONASS). |
