Nashville, IL | I believe you can divide runs just like in a tile plan. Open your installed tile to a map, then right click and click on edit layer. It will open a tile plan editor looking page. You can then use all the same tools that you have for planning tile to edit your installed tile. I do this quite often as we might change tile size thru a run and instead of stopping the plow to change the tile settings, I just mark it and change it in SMS.
You do have to have SMS advanced with water management, which Im assuming you have. | |
