East Central, Nebraska | just as said above you can take nmea out from the trimble equipment to make the integra do what it has to do. if your buddy is getting away from the ezsteer is he keeping his current trimble monitor and antenna? if your getting it all whether it be a 500 or 750 or 1000, they both can be made to function together with your integra. I do something similar with my trimble/agleader equipment. just setup the trimble to output nmea strings to the agleader and your good to go. if you do not have the trimble monitor you can find one pretty reasonably and be steering for cheap. but as said above the integra will not control the ezsteer.
the other option would be to sell the ezsteer and get ahold of a ontrac and that can be controlled by the integra with similar steering results. ontrac is agleaders version of the similar assisted steering device that trimble has (ez steer or ezpilot)
clear as mud, right? figure out if your keeping the trimble display or not and report back, we can help you out. | |
