| co2shaun - 10/4/2017 18:29
The 2050 should work well for you. You should be able to make most any clutch that uses a 12 volt signal work with a field iq module. Depending on how often you need to move data, you may be able to get by with using a USB drive to move your data. It isn't automatic but once you get it figured out it isn't hard and doesn't take too long.
That's good news. Row shutoff will be the cat's pajamas in our 30 csr fields. I don't remember now and can't find it yet if you need both the master control field iq switch and the 12 switch box below it or not. Alot of reading left to do. Thanks for the info shaun
Thinking about putting a spray system onto the planter instead of row shut off for now and eliminate a sprayer pass. I suppose I need a rate controller+field IQ? More reading...
Edited by wompass 10/5/2017 00:12
