Central Nebraska | Update: We ran on Sunday and the monitor was still wrong till about 4pm then was back to 9% off. Ran good for an hour or so then back to 32% wrong. I've check the power supply and it was good. Did find that the Can Bus voltage was different that what Ag Leader said it should be. Between pins 2&3 was 2 volts and should be 1.4. Between 3&4 was 2V and should be 2.7v. So maybe my issue is that, but that raises the question why and how to fix it. Any ideas?
The guy at AL said it was time to call the dealer and he believes he has exhausted all options. I asked how to test the Mass Flow and he said since it was installed at the factory it was JD problem. Called JD and he said that there wasn't any info on how to test it.
My JD guy said that he had someone that had issues about an hour before he would quit for the night. Ran it in corn with no issues. Checked out the updates for the sensor and there wasn't any that applied to my machine.
Thanks | |
