Posted 9/24/2017 23:43 (#6268635 - in reply to #6268619) Subject: RE: Best onboard scale for semi
Saskatoon, Canada
I have Air-Weigh on 2 of my trailers and on the truck. Just install sensor and monitor on each axle set and sends the signal thru the abs wire to the truck. Just make sure the unit in the cab is powered by the same abs power/trailer aux. Very accurate once calibrated. Works on air bags or spring axle.
