| Yup, that's the setup I'm talking about. The levers are connected to potentiometers under the plastic console cover. A couple questions for you.
First off, you say this is a 2006 production machine. Does this machine have the later instrumentation that shows a green light when a remote is on? Does the light come on intermittently when all the remotes are in neutral? That's usually an indication that one(or more) of the potentiometers in the levers have a problem-the lever is in neutral but the pot. is commanding that particular remote on.
Also, when you start the machine first thing in the morning, does the instrumentation give you an "aux neutral" message when all the remotes are in neutral? That's another indication one of the pots. has a problem.
