Posted 7/24/2017 07:36 (#6145511 - in reply to #6141044) Subject: RE: Massey c1000 and incommand isobus
Central KS
You're probably going to need an ISO hijack cable from Ag leader so that only the InCommand is reading off the ISObus. That cable essentially terminates the Massey ISO at the ibbc connector and lets you use the ibbc for the Ag leader screen. If you're trying to share the bus, you'll need to change function instance on both displays.... most setups ive done I usually bypass the agco side.
