Pickens | If that seat switch is not functioning correctly, will give the same problem as the piston seal going in the directional unit...
I found mine defective in rough ground, and then shortly thereafter, failed completely...new switch, and back to normal operation.
You CAN wire in a temp toggle to activate the circuit for testing...
When sitting, flip the switch, and see if you have any problems for the duration of that "run".
Good Luck,
CF | |
