Hendricks MN | It's a good time to replace the beater drive belt while you have things apart. Start by taking the clean grain elevator belt off. Then to take the rotor drive sleeve off take the lower pin off and roll pin out of the adjustment screw, push the button to slow the rotor speed down until the top comes off. The variable speed belt on the head doesn't need to come off just loosen up enough to slide the long belt inside. | |
