Have a customer with a very similar setup. Photo's are a little old now as FM1000 has been replaced by XCN2050. XCN2050 with FIQ to operate FIQ Trailing Spreader only. The XCN2050 is preforming AutoPilot, Task Controller & VRA duties. In your case Yes, if you want to operate Hardi ISO through a Pro700 with VT - as stated by Trimbleman the 9 Pin In-Cab ISO Connector is required to operate the Hardi Grip. This Magnum was not factory fitted with the 9 Pin so it was fitted beside the two Diagnostics Connectors at RH rear of the cab. ISO Task Controller is required if you want section control capabilities as well. Dual Pro700 would make your setup pretty neat if you wanted to view your Guidance & Coverage on one display and the Hardi VT on the other. Just need to have the Task Controller Unlocked on the display that running the GPS. Norac Boom height control is also operating through the Pro700 VT, unsure how this was complete but customer did this on his own accord and not officially supported by Hardi. But does make the cab nice and neat. One good thing about this customer was the other day the Magnum had a spreading job to complete which meant that the sprayer had to be unhooked, but at the same time a field had to be sprayed. Customer pulled out his seeding tractor - Steiger Rowtac with the same in-cab setup. Customer was spraying with in minutes not days or hours (got to love ISOBUS).
Edited by Camel 7/4/2017 08:37
(IMG_3327.JPG)
(IMG_3326.JPG)
(IMG_3328.jpg)
(IMG_3329.jpg)
(IMG_3330.jpg)
Attachments ---------------- IMG_3327.JPG (54KB - 320 downloads) IMG_3326.JPG (79KB - 315 downloads) IMG_3328.jpg (85KB - 283 downloads) IMG_3329.jpg (71KB - 293 downloads) IMG_3330.jpg (116KB - 299 downloads)
