NW Wisconsin | I had the same issue this spring setting up fieldIQ on a 2050. It took a little while to figure out but ended up I had remote master enabled along with implement lift. I was getting the same thing as you. Lift switch working, but kept saying Master Off when I toggled the master switch on switch box. And I could not start seed drives. Once I disabled remote master it worked perfectly. As far as your canbus wire extension, I wouldn't worry about it too much if it works. My setup has about 40' of 4 wire black cable used as canbus extension with no issues this spring. | |
