NW Iowa | I have a wiring harness that plugs into the rate controller and then connects to the raven flow meter and also had a 2 pin flat I would call it SAE connector with a green and yellow wire. I cut that off and used the yellow wire to connect to another harness that had a red black (I connected my power which I ran off the 7 pin tractor connnector) and yellow wire that went into a small box and then out came a red and black or red and white can't remember those wires were then connected to the pump. I guess I assumed the yellow wire was controlling the pump thru probably voltage of some sort. I did a quick sketch I know it does not look very nice but hopefully gives you and idea.
Thanks
ANthony
(image.jpg)
Attachments ---------------- image.jpg (54KB - 122 downloads)
