Search Forums | Classifieds (114) | Skins | Language
Trimble field iq implement lift switch? ?
Bigboyfloyd
Posted 4/20/2017 04:15 (#5972598)
Subject: Trimble field iq implement lift switch? ?
SW Michigan
This is installed on a 1770 deere planter. Which module do you connect the lift switch cable to? Rate and Section or Seed Monitoring? Both have similar plugs but rate and section plug says IMP SW, and seed monitoring say IMP LIFT, so I'd say seed monitoring. For some reason it's not seeing the lift switch I've tried it both ways and no luck. Lift switch is enabled. The switch is a deere button type 2 wire. The cable they sent me does plug right in on both the module side harness and the switch however the cable only has one purple wire on module end and 2 blue wires on switch end. The IMP plug from module has both purple and blue. Shouldn't that cable have 2 wires? This is the 3rd planter I've set up with Trimble you'd think I'd know what I'm doing by now. Hahaha.
