Osnabrock ND | The front drive shaft is starting to leak at the tranny end. I've never had any problems with this before so I'm new at this. Is it a big job to replace the front seal or is it better to have CIH do it. Don't have a problem trying to do it but if need special tools and if I screw it up then have to take it in. Looked at it a little, got the cover off and the yoke doesn't look like its easy to get off. Also how do you get the shield off without wrecking it.
jeff | |
