| jedeka - is that $25 from the CIH dealer?
I don't have much experience with CIH combines but I've replaced micro switches on New Holland skidloaders and the NH loaders use switches made by Cherry. I could imagine CNH using switches throughout the product line by similar manufacturers.
If you go to digikey (www.digikey.com) you can find lots and lots of micro switches. Typically the switch will have the manufacturer and part number molded into it and you can search using that to find a replacement. I know the switches I've replaced are typically less than $3 much cheaper than the dealer.
Hope this helps. | |
