| Ryan, I have set up or looked at several problems with projectors at work, and about the only way to fix the problem is to be at the machine. Sorry. You might look in your Control Panel at the Display properties, and see what can be displayed for the 2nd setting. If you are running XP, click Start>Control Panel>Display>Setting Tab. In that tab, you should have settings for 1 (your monitor) and 2 (the output from your video connection on the back of your system). I believe the 2 settings are what is used for the output of the video connection when you hit Fn-F8. Perhaps a better setting would allow the Slideshow to be projected properly.
Try setting your 2 setting the same as your 1 setting and see if that works. I assume the slideshow works when viewing before hitting Fn-F8. | |
