Posted 7/26/2008 00:02 (#422146 - in reply to #422127) Subject: Re: MX215 autosteering
If your led light off of the nav is blinking, you have it hooked up right with the connecters plugged together. As for your other issue, you need Autopilot Toolbox program on a laptop to connect to the Nav and load a specific profile for that tractor and then go through a calibration procedure. Your local dealer should be able to help you out with that.
