sullivan il. | obviously none of you guys have had to syphon gas with a hose because using the right size ball bearing for the hose is essential an old trick to seal off while you take your next breath to suck it father up the hose if done properly you will not inhale any gas much safer this way but must have a good set of lungs to be able to do this. Which that is what he said now all you self righteous guys need to grow up and get your minds out of the gutter | |
