| I don't know if this will help or not...
We had an SPX this spring using EZBoom w/ EZGuide that had the same issue. We found that the "throttling valve" was open and should have been closed. I don't know if this model of SPX has this valve, but it would be worth a look. The other things to check are the particular settings based upon what flow meter and pump set up that you have.
BTW - the valve, if you have one, is after the flow meter on the boom side of the spray supply line. It is a banjo valve that has a hole drilled in the valve itself.
Joe | |
