Posted 6/1/2008 10:30 (#388639 - in reply to #388530) Subject: Re: Insight Direct Command ?
Creighton, NE
Thanks Ted,
I would normally stay the same on the application rate or GPA. I will set up 2 or 3 different tank mixes with various different rates of glyphosate and then be able to choose the correct mix from the product list when going from field to field.
