Central MO | you are looking for the .ilf files, ibk is a monitor backup file SMS will not read it. Your new files will be named using the dates they were collected. The first 2 digits indicate the year, second 2 are the month, next two are the date, last two represent the file count for the day, so 08042200.ilf will be the first file recorded from April 22, 2008. The files should be stored in a folder on your card (it will be named 2004305445 or something like that, its you monitor serial no) If you don't see any files like that on your card they have not been copied to the card. In the insight go to setup > Console > Memory > Copy all Log Files, go ahead and accept the warning box and it should save all your files to the card. Once you copy to the card take it to your PC and read the files into SMS, after 30 days the log files will be deleted from the monitor, it will still have the planting maps for harvest, but if something happens to the card before you get to the computer you only have 30 days to go back and copy the files again, if you wait longer than that your screwed. | |
