Posted 12/14/2014 10:47 (#4239347 - in reply to #4239271) Subject: RE: How many hd/yr to justify a hyd chute?
Southern Minnesota
I used to own that exact same headgate. It was a pile. With the angle needed for the vaccination doors you could not get tension on the neck.
Call Stronghold/Palco or whatever they are called now & get the traditional flat style. You will put so much pressure on the neck if you have too tight they will stagger out the chute.
