Posted 11/3/2014 19:54 (#4159017 - in reply to #4158894) Subject: RE: Barbed wire unroller
Southwest Missouri
We made one to pull behind a four wheeler it can do two or four it just rolls on the ground we use old wore out disc blades to keep the wire from hitting the frame. I like using our bale bed the best that way when you get to corners just lift the arms up and you can work with the wire but like you said you can't always use a truck
