C-IL | The PF90350 is a complete kit with instructions that includes PF80754 harness and is available. The PF90350 is ordered thru the Sales side of the business and PF80754 is the replacement harness ordered thru the Parts side, each having their own markup price. The PF90350 will not always show up in the Parts system, it just depends what Parts system you are using. If using the Dealer Parts system it should show up and may not on the Web system.
Unsure as to why you had to hook it up the way you did but am glad you are tech enough to figure it out. I will see it this wire issue on the iTC is common or if you have a fluke. | |
