Search Forums | Classifieds (200) | Skins | Language
John Deere L120 - Disabling reverse switch???
Glenn
Posted 7/20/2006 00:18 (#28146 - in reply to #28137)
Subject: Re: John Deere L120 - Disabling reverse switch???
I think the switch is in a bad spot because you must look forward to find the switch so you can back up with the blade turning. If they need a switch then it should be behind you so you have to turn around and look back to back up. It is annoying trying to mow around trees.
