Search Forums | Classifieds (33) | Skins | Language
7140 CIH or 4955 JD?
hwdcne
Posted 7/19/2006 14:01 (#27964 - in reply to #27934)
Subject: Re: 7140 CIH or 4955 JD?
Soutwest Ks.
I think a lot depends on what you have run in the past. If you ran an older series Case i.e. 1370-2590 you'll like the 7140 as it is an improvement, however if you have been running Deeres, I suspect you won't be totally pleased with the 7140. My personal opinion is that the mechanical on a Magnum is very reliable but somewhat lacking in the asthetics department.
Incidentally I am running a 7240 and a 4760 and have had a lot of time to compare. I do feel either tractor will give you good service and it will primarily depend upon your likes and dislikes.
