North west MN | The trimble 250, 500 and agleader 250, 500 are the same. I think you will get better support from your brother and AgLeader. As far as the diff between the 250 and 500.
The 250 you can't use EZ-Boom the 500 you can
The 250 you can't upgrade to OmniStar hp and xp the 500 your can upgrade to OmniStar XP,Hp or RTK
Not as much in the way of field records as the 500
Half as many led's for guidance as the 500.
Half size screen of the 500
The250 Can't be used on an autopilot The 500 can
If you plan on ever using it for more than guidance or the ez-steer go with the 500
