Insight Autoboom
Lightning
Posted 2/5/2008 17:56 (#301941 - in reply to #301851)
Subject: RE: Insight Autoboom
Clatonia, NE
If you want to use an insight for auto steer, it can only be used with Auto Pilot. If you want the Insight to run your paterns, you have to use a TSIP (Trimble) reciever with your Nav II controller/Insight. The insight will do multiple product controll along with the AP interface. You need a direct command kit with multiple modules tied together and an unlock. If you're setting up from scratch, I would suggest you use Raven Flow control parts. I hope this helps!
