SOUTHERN MN | The factory that I work at makes most of these products that you guys are talking about. Instead of the 33 tape I would use the tape that is called 130C. It is a lot thicker and you can stretch it out really nice and it seals up really well. You could get it in widths of up to 2 inches wide. Another really nice product would be shrink tubing that has a plastic core in it and all you do is put it in place and pull the plastic ribbon out and it shrinks way down with no heat needed. Thanks for buying our products guys. | |
