Posted 9/4/2013 13:37 (#3307351 - in reply to #3307188) Subject: Re: JD 2950 cab tractor clutch issue
Kingston,Mi
Did not see any mention in your narrative about starting bleed process with a full reservoir of brake fluid. When I have rebuilt or replace the slave or master cylinder, it has never been more than a dozen or so strokes of the clutch pedal, pedal down then open the bleed screw, wait for it to quit running , tighten bleed screw and repeat.
