WC MN | You stated on May 4th that you had 428 acres in. Were those on your best acres? Tiled soil or better drained soil? We started May 7th when the ground was finally fit. So what are you comparing the 40 BPA more stuff too? Your last planted corn which you estimated would be around May 15th? How much sooner did your corn emerge that was sitting in 42 degree soil than some that was planted a week later. Serious questions, just curious what you are comparing to. BTW my May 7th corn will out yield some planted May 13th by 100+ BPA. I also have some planted May 18th that will be way better than May 10th planted corn.
Edited by IALTO 8/27/2013 11:14
