East-Central Ontario | V-rake raking 2 12' windrows together, I start on the straightest side like you, rake the 1st and 2nd inside windrows together, then 5th and 6th, then 9th and 10th, so on across the field then come back across the field raking the ones I skipped. No particular reason why, just makes for fewer sharp corners. I don't usually lift it up. Then I do the outside 6 rounds from inside to outside the reverse of the direction it was cut. | |
