Central Mo | Recently purchased a used 1770nt with the hyd drive, had a 1770 with mechanical trans before. Not too impresed with the pile of seed when you stop to either go over a terrace riser or just to check something. Also, seems to take too long for the seed to start dropping when I restart. I am running the precision drives with an Insight. Might be looking for a mechanical drive to put on this thing unless I can change this thing to work better.
Btw, on flat running it does great, just doesn't work as well on the hills and terraces as well as I would like. |
