Faunsdale, AL | Only thing I would consider with the 1000 rpm blower is the selection of higher hp tractors that will be available to use on it. Sometimes the one that needs to go on the blower is the one that is too big for convenient use on any other piece of equipment you're running to put up silage. Around here that means it has a 1000 rpm shaft or at least the option of 1000 rpm
Older NewHolland/John Deere blowers were larger diameter for 540 and smaller diameter for 1000, both direct drive. | |
