Concordia, KS | Where you set it depends on seed size. If you want to put down 150000 beans that are 3000 seeds per pound, you have to put on 50 lbs of seed down. If your beand are 2000 seeds per pound, you have to put down 75 lbs. There is no magic setting that will work because of the variables row spacing, seeding rate, and seeds/lb.
Edit: you will have to switch seeding rates as your seed size changes with variety. That is the problem with a drill.
Edited by Swenny79 4/26/2013 23:14
