Posted 4/25/2013 21:22 (#3063283 - in reply to #3062896) Subject: Re: Need help plumbing Hiniker Anhydrous heat exchanger.
North Central IN
Kelley engineering set up mine. Pretty sure it has two 3/8 lines running from manifold to cooler, then 1/2 as second line to two knives. I put those two lines where my wheel tracks for the wagon run. In real dry dirt they smoke when the tires run over the cut.
