| Once you have used the Baseline or any RTK signal I don't think you're going to be satisfied with WAAS (if thats what u are using) anymore. The ability to go anywhere in the field once you have your 1st strike line is something you get use to real quick. Setting your overlap to 0 means less time in the field to. We use our Baseline for planting, spraying, harvesting and fall tillage and haven't used WAAS since we got the Baseline and don't want to again. Just remember the 5 mile range of the Baseline is circumference not radius. | |
